My cricutmaker is failing to cut when I draw prior to the cut. If I foil and cut it works. It will print and cut snd do ordinary cuts. As soon as I put a cricut pen in it will draw but not cut. It will say the blade is stuck and to clean cutting area. I have done this and changed the blade. Still.no good. Help please.
Make sure you have the cricut pen in the correct holder. Make sure that what you want cut is marked as a cut in the screen before you Make it.
