I haven't used MTC for awhile now, but the last time I did I was able to access the Gallery. Now when I try, it says it is unavailable. Could someone give me some instruction please? Thank you!
Do I need to redownload? It use to be free with Zing, now it looks like I have to pay. When I went to the official MTC software site and even that link came up unavailable! I am so frustrated.
The MTC site looks to be down right now. I have no clue if it's now permanently gone or will be back up tomorrow. No one tells us volunteers ANYTHING. This is why those two links above for recovering files is available to MTC owners... some of us worked to get these two sites set up to provide files before the Gallery was gone forever.
If you need help with your Zing, post specific Zing questions and I'm here. But I also don't know if this forum will always be here or not. Nothing relates to MTC is tied to your Zing... which is KNK USA's product. MTC is its own product and the owner abandoned the software years ago. If you need my help and the forum isn't here, then you should take note of my email right now: [email protected]
@bea4him, @SandyMcC - the error message you get when trying to access the make-the-cut.com website is the same error as the PCS. I am suggesting that this is the beginning of the end.
The Gallery is hosted on the same server, so same error message, again, not likely to come back. The next step will be that this forum disappears.
So MTC is no longer going to be available? Is there another software that can be used with the Zing? Also, when I saved files from MTC, they were always saved as MTC file. Is there away to change them to just SVG files? Thank you both for the input.
@bea4him - yes other software choice that is very popular - Sure Cuts A Lot (SCAL) supports lots of cutters including Zing and other KNK cutters.
Remember its just the www.make-the-cut.com website that is not working. MTC works just fine, and will continue to work for a long time yet.
For converting, open your MTC file:
- Select All (CTRL+A) - File => Export => Sel. to SVG
File is saved as SVG. But you have all the time in the world. MTC still works, and will continue to work until such time that Windows decides not to support 32 bit programs which is what MTC is. SCAL has both 32 bit and 64 bit versions available for Windows. If you have a computer 3 years or younger chances are very likely it's 64 bit, but MTC still works just fine. That will continue for the foreseeable future.
