Good afternoon.
Does anyone recognize this font or know something that is very similar.
I am considering buying this steel rule die for use on banners & bulletin boards but also need ! @ # $ % & - which are not available with this die.
If I can find a very similar font I can cut those special characters with my cutter.
Thanks in advance for any help.
If you google it you will see the J is very similar as is the Q. X
