How many downloads do I have to purchase?
Jean6353Jean6353 Member Posts: 6
edited February 29 in General
2 computers, one at home & one at lake, how many downloads do I have to purchase to use MTC on both? I am using Fun Time now, I just pick up my Bosskut, the dongel and run to the lake.. Hoping MTC allows more than one down load per $'s.
  • Liz_ALiz_A Member Posts: 10,581
    @Jean6353 - one purchase, can be installed on 2 computers. The idea is that you are not using MTC on both computers at the same time =).
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,594
    edited March 2
    If you don't already own Make the Cut My personal view would be Do not to buy it
    as its not be actively support nor updated and its future is somewhat in question
    I would suggest you trial Sure Cut a Lot software it lists Bosskut as a Compatible cutter and is still actively supported
    its licence will also allows registration on 2 computers
  • Jean6353Jean6353 Member Posts: 6
    Thanks you for the help..
    Crazy _Mr_Zing, Are you familar with a Bosskut Gazelle.. Having trouble and am desperate for help, The plotter keeps tapping before it cuts 2-10 times, then it cuts perfect. Worried I am hurting the machine and the plotter.. Thanks much if you can help! Jean
    @Jean6353 - are you using Make The Cut!?
