Help
TammyKTammyK Member Posts: 1,043
MTC wont open up.  It shows a error message of
 An attempt was made to access an unnamed file past its end.
Tammy www.dtkreations.org The 3 C's of life: choices, chances and changes ~ You must make a choice to take a chance or your life will never change.
  • Liz_ALiz_A Member Posts: 10,714
    @TammyK - what happens if you double click to open an existing MTC file, ie one ending with .mtc?
    @TammyK - OK I guess I resolved this problem a long time ago, lucky you :)
    Go here: C:\Users\username\AppData\Local\Make The Cut! Library
    Copy all those files to another folder, then delete them.
    Go here: C:\Users\username\AppData\Local\Make The Cut! Temp
    Delete all those files.
    Now try reopening MTC.
    The file in Library are loaded fonts, and saved shapes. If all is good, copy the Library files back.
  • TammyKTammyK Member Posts: 1,043
    I am trying to open in dif locations and even just MTC its self.  Still getting the message.
    @TammyK - what version of MTC?
    Its the newest version
    I uninstalled it and reinstalled and still getting the error message
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,617
    Maybe uninstall
    Delete the follow folders
    But you will loose all you setting and custom shape etc
    Make The Cut! - From >C:/Program Files  or  C:/Program Files(386)
    Make The Cut! Library - From >C:\Users\username\AppData\Local\
    Make The Cut! Premium - From >C:\Users\username\AppData\Local\
    the reinstall
