I have a Black Cat Cougar that I have not used in a while.
I purchased it through Thatsscrap and I was on the Thyme Graphics forum.
My machine was run by Signcut and I would have to contact Dawn Grantham on the Thyme Graphics, every so often, to re register my signcut to get it working. I can not find Thyme Graphics anymore and I can not get on the American forum. I use to be on it and now it will not let me register. Can I use my machine with Make the cut and not use signcut?
Hope someone can help.
ltgrandma
With that noted, you can use Make the Cut with a BC Cougar. It is the first cutter outside of the older Cricut machines that Andy added a plugin for in MTC. However, it pains me to say that MTC has not been updated in years now so if I were looking to add a new software program to use with my cutter, I would probably look at SCAL (Sure Cuts A Lot) from Craftedge as it continues to be updated and also works with the Black Cat Cougar and it’s replacement the Silver Bullet line of cutters. SCAL is also the software program used with the Silver Bullets and is the only program that they support on their forums.
I also appreciate you explaining SCAL to me. I most likely will be going along with that program and will be back for help in learning.
