Just Upgraded my Mac OS
tvoss123tvoss123 Member Posts: 212
edited May 2018 in Help for Make The Cut
I was afraid of this, but needed to upgrade my Mac OS. It is now El Capitan version 10.11.6
So I am getting a message when I attempt to open MTC.  "The application X11 could not be opened."
Is there a way to update the application X11 so that MTC will open on my Macbook Pro?
Thank you for any assistance you can give.  My previous OS was 10.7.5
I use MTC with my ZingAir.
  • Liz_ALiz_A Member Posts: 10,898
    @tvoss123 - no updates beyond the version available for download on the MTC website. You have "allow" the application to run, given that it is not an approved Apple application.
    Apparently, totally removing the application with a "cleaner" then reinstalling MTC and the gateway and allowing the non-approved MTC to run should work.
  • tvoss123tvoss123 Member Posts: 212
    I will give that a try.
    Thank you so much.
