I need to know if its possible to use CUTOK DC 330 with MTC for print and cut purpose, I do not see the registration marks options in MTC which works with CUTOK, if there is any link or video please share.
Are you using the windows version of make the cut ? the mac version only supports the older knk models
If not familiar really with cutok cutters
In Make The Cut in the Help > advanced menu there is a option to install a cutok driver
I'm not sure what version driver this install you may have to check the cutok webpage for the latest driver http://www.cutok.com/Support.htm
You may have to install the ftdi driver theres and option in the help > advanced menu but once again you may have to check the ftdi wepage for the latest driver
in an older discussion there a comment suggesting the the bosskut gazelle plugin can be used ? http://www.make-the-cut.com/Download.aspx Not sure if this is current as I recall windows 10 requiring new drivers form bosskut
I tried what you suggested, but I do not get option to set the cutter as per the registration marks. it just goes on and starts cutting, I am in trial version, using in Win 10.
My experience with the Gazelle is that the original version of the machine cut perfectly according to screen layout without the use of registration marks. The updated motherboard messed that up, so that the only way to get accurate print and cut projects with it was to use the Funtime software that came with the machine.
http://www.ftdichip.com/Drivers/D2XX.htm
Please suggest what can be done.
Thanks
