Not Sure how to bring my downloaded files into mtc
Hi, I have some downloaded svg files which I haven't used yet because I can't figure out how to get them to show up on my mtc mat. Does someone possibly have an idea of what I need to do?
if you file are .SVG Use the svg import function there a button on the tool bar or you can use File>import>SVG If you design is size critical confirm the dimensions as svgs created in other applications sometimes import as a different size and therefore may require resizing
@RoseyRita - sometimes svg files you purchase are in a zip folder, so they would have to be extracted from the zip folder first!
http://www.iloveknk.com/0um/KNKZing/KNKZingwithMTCUserManual.pdf
