Hi Everyone!
I haven't used my Cougar in quite sometime. I need to cut some vinyl for a friend. Can't get the cougar to start. It shows klic N Kut series. It seems like something else was listed before. I went to make the cut and looked I did not find the KnK section that said also workable with the BC cougar, so I downloaded the Klic N Kut plugin but still not working. I may have never used this laptop for the cougar but thought I did. KnK was already listed as one of the cutters though. How do I solve this?
Thanks in advance
darlene
If you are only showing the KNK cutters in the "cut with" then you don't have the Cougar plugin downloaded and install. However, you don't need the Cougar plugin to get it to work. You can use the KNK plugin for the Cougar. It is probably the better choice to use over the Cougar plugin since it gives you more choices like "knife point" cutting. With the Cougar one, you had to go in two inches and then over two inches to get alignment as I recall.
You just need to use the KNK Maxx choice (not the Maxx Air) and make sure the baud rate is set to match that of the Cougar's as it is different from the Maxx cutter. Not sure if that is all for general cutting - (my sister has my old Cougar so I can't check on it specifically.) It has been discussed on here several times before so you might do a search and see what you can find. I don't recall anything else though. you can do the "test" and see if it works before attempting to cut. I know it works because I used it regularly with my Cougar and still do the same with the Silver Bullet.
about and x and y being reversed on blackcat machines . does that ring any bells?
Darlene, it’s not going to draw the mat into the machine like a cricut or silhouette type cuter that does. IF you are putting the mat into the machine with the edge in from the front of the cutter like you would with those machines, that is not right on these cutters. With the Cougars, SB and some KNK and other cutters, the mat is pulled into the cutter from the backside of the cutter so you need to load the mat from the backs of the cutter. So the edge is in from the back, and the bulk of the mat is hanging out of the backside. You also need to make sure to take the cutter “offline” and set the “orientation” or starting point by pressing the “target” or “bullseye” button and then put the cutter back online. This is where most people make mistakes and why the mat is then spit out if you don’t load the mat correctly or forget to set the orientation with the cutter offline and then put it back online. If you are using the KNK plugin with the "knifepoint" option to cut with, it will start cutting where you place the tip of the blade, and pull the mat into the cutter from the back as it cuts.
if you need some further refresher help, I believe you can use Sandy’s MTC/KNK Maxx manual for most of the basic information.
in regards to the X/Y being reversed when doing a PnC, that means when setting the X/Y - one is a positive number and one is a negative number - if you have the cutter using the Cougar plugin and are calibrating the cutter it’s one way, and it’s flipped if you are using the KNK plugin. This means if X is positive and Y is negative in the Cougar plugin, the X would be negative and the Y positive when using the KNK plugin. (I don’t recall which way it actually is off the top of my head and no computer or cutter right now where I am to check but it is in several old conversations here on the forum.)
So thankful for your help.
