Does Silhouette Cameo 2 or 3 work with...
a1jomamaa1jomama Member Posts: 92
Does Silhouette Cameo 2 or 3 work with MTC?
Best Answer
  • a1jomamaa1jomama Member Posts: 92
    edited August 2017
    I'm about to buy a silhouette Cameo 2 or 3, but if not MTC compatible..then I don't want to get it. So please let me know if either one works with a 2 or 3. Thank you! :smiley:
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,603
    edited August 2017
    There a is plugin for the Cameo 2
    I think but not sure there may some limitations with regard to print and cut in regard to mat orientation I'm sure a cameo 2 user can clarify this
    There have been discussions of cutting to the Cameo 3 from MTC but the position of the cutting is incorrect and use of the 2nd tool is not possible
    Silhouette have made some improvement in their studio software with version 4 unfortunately they still don't allow import of svg in the free base version
    Ironically this appears to make cutting from MTC via SVG export to a Cricut machine a more plausible option
    Make the Cut has not been updated for some time so compatibility for newer machines eg Cameo3 , KNK Force, KNK Zing Orbit has not been added so is non existent or limited at best
    Considering this it might be time to place a cutters suitability for the required task ahead of whether it is compatible with make the cut
  • Liz_ALiz_A Member Posts: 10,622
    @a1jomama - you can purchase the Business Edition of Silhouette, and that version I understand lets you import SVG files to cut on the Cameo. You can use MTC to do your design work, then export as SVG for cutting with the Silhouette program.
  • gll5613gll5613 Member Posts: 51
    edited August 2017
    All three Silhouette Studio upgrades, Designer Edition, Designer Edition Plus, and Business Edition, accommodate importing SVG files. The Business Edition also exports in SVG, JPEG, and PDF formats (excluding designs purchased from the Silhouette Design Store) in Studio Version 4.1, which was launched as a public release on 8/21/2017.
    Post edited by gll5613 on
    I find the Silhouette Studio (including Designer edition) to be very difficult to use and even SEE on the screen compared to MTC!. I am making all my designs in MTC and then exporting as SVG and then importing them to Studio to cut. Reason being, MTC! does not match the print area on the Silhouette yet and does not have all the paper/vinyl cut/blade etc choices yet. Looks like an update would allow me to never open Studio again. Saving me the hassle of trying to export, find the file then import into Studio.
    I tinkered with Sil Studio Basic a little it seem quite limited and also not very intuitive in operation although that may because I'm so use to MTC
    So Svg export form MTC to Sil Studio DE is a good option
    or MTC SVG export to Inkscape to DXF to Sil Studio Basic works for plain cutting files but is a little more time consuming
    I really take issue with companies that put limitations in place for the sole purpose of what would appear to gouge user further in the sale of cutting designs from their store
    For which this seem the only reason for not allowing SVG import on the Sil Studio Basic Version
    Although the upgrade to DE is not that much extra cost I think I would be inclined to Give my money to Craft Edge and use SCAL least they would not chain me to silhouette machines
  • lonestarlonestar Member Posts: 58
    I've had the Business Edition of the Sil software almost since it came out but only used that software for print and cut.  Now that they allow the user to save to svg I have started to use it and like it.  They have added quite a few nice features and it relatively easy to use.
  • CheercoachCheercoach Member Posts: 13
    I have just upgraded my MTC because Silhouette version 4 does not even have a simple ruler setting.  You have to purchase the designer edition. After all their upgrades in version 4 and no ruler? Really? I spent a ton of money on purchasing designs in the Silhouette design store and I want to use them but version 4 is clumsy compared to MTC. I have read your comments, but isn't there a simpler way to use their designs besides tracing. I don't have that skill down yet. Help?
    @Cheercoach are you asking this in relation to MTC or Sil Studio
    I would like to use my designs that I bought in Silhouette Design store and use Make The Cut to do my designs instead of Silhouette Studio software.
    @Cheercoach - my understanding is that if you can save the designs onto your local desktop, then you would take the .studio file and upload it to a website for conversion to SVG which would allow you to import it in MTC. The website is:
    http://www.ideas-r-us-software.uk/FileConverters/SilhouetteStudioConverter.aspx
    Be sure to read the known issues section.
    @Cheercoach -  Basic Studio does have numbered grid markings on the virtual cutting mat that can be used as a simple ruler. It's not the same ruler available in the paid upgrade versions, but it's free and available to all Studio users. Go to Page Setup>Cutting Mat>Reveal and increase the reveal percentage enough to display the mat's grid, numbers, and right side markings. If you want further divisions, keep the reveal around 80% or less, then go to the Grid options, select Show Grid and specify the Spacing, Divisions, and Color. If you want the mat to always display, go to Preferences>Defaults>Always Display Mat and select that option.
    As Liz says http://www.ideas-r-us-software.uk/FileConverters/SilhouetteStudioConverter.aspx
    be aware that this tool has known limitations one being it doesn't handle raster or fill content well
    The also have a Studio Library File Extractor not sure how well this works and there seem to be a issue with cloud based libraries ?
  • SheriSheri Member Posts: 539
    After reading this thread are you saying it is possible to use and cut with MTC with a cameo 2 or 3? I am wanting to upgrade from my cricut.  Looking to buy over black friday.
    @Sheri nothing has changed in regard to cameo 2 MTC will cut to it as it always has
    how well it did that I don't know
    With cameo 3 as there is no updated plugin the short answer would be No or very limited support
    As Any cutting would not be positioned correctly I guess it would be possible to workaround this by calculating that offset and allowing for that in you design it still would be a little experimental
    Cutting from make the cut using the 2nd tool holder would not be possible
    I think Print and cut with be problematic if not impossible
    I believe the Cameo 2 production maybe being discontinued
    Unfortunately as much as I like MTC it being compatible with any new machine purchase would not be on the list of my requirements
