I have been on a popup card kick... I found this image on the internet:
And thought that I could recreate that in Make The Cut. So, I set my Snap Position to 1/8" and just started drawing lines. Once you get the first staircase done, it's just a lot of repeating.
That was the easy part... The *hard* part is folding it so it looks right! Either way -- it looks COOL in real life.
You need to cut it out on 100+ lb. cardstock. I used 110 lb printer card stock and it worked perfectly. The MTC file I made is attached for all to use. It's not 100% exactly like the original one -- only because i wanted it to fit on 8.5x11 paper.
Here are some pics of the one I cut out...
MTC file attached at the bottom of this post.
Have fun with this!
-andy.
I don't often test my code... But when I do, I do it in production.
Peggy
Cutting with Mr Maxxie
Waiting on Maxxie's new brother....Force
This one is a lot easier to cut/fold up
MTC file attached!
Thanks for the inspiration.
Moderation in All Things should be Practiced Sparingly
In KNK Love with my Zing, Eagle and the Support!
See the post here.
Improved template posted here.
Carol
Extreme Cards and Papercrafting
MTC file attached
