Love this little box but can't convert the file so am wondering if some smart person can make a file for them. can't upload a picture but here is the link.
If you join the Pazzles Craftroom, the file is posted in WPC format. If you would like to cut the file from Make The Cut, 1. Open the WPC file in one of these programs: Pazzles, Gazelle, Funtime, WinPCSign, or FairyCut. (Funtime Lite is a free download from here:) http://funtimescrapbooking.com/Software/Funtime_Lite.aspx 2. Print to PDF using Adobe PDF or the free Cute PDF Writer http://www.cutepdf.com/download/CuteWriter.exe 4. Open Make The Cut. 5. Import Strokes only (Ctrl+Shift+D) PDF into Make The Cut. 6. Click on the design to select, Break (Ctrl+B) 7. Hold down the Shift key, and Select all of the inside pieces. 8. Send selection to their own layer by clicking on the smaller of the two green Plus icons in the lower right corner of the screen. Hide this layer. 9. You are now ready to cut to your MTC-compatible cutter.
Love it. This look similar to a photo cube I did a couple of years ago. Will have to try and find the file and see if I could do some adjustments on it.
Penny
in Albuquerque, NM
"Not all those who wander are lost." - R.R. Tolkien
looks like it is made from a rectangle and trapezoids I am not good with the numbers of figuring out the sizes but the shape doesnt look too bad.
Cutting with a 15" Black Cat Cougar and a 24 " Silver Bullet
T shirts with a Heat Press Nation 15" Swing away press
Foiling around with the Foil Master
don't have a membership in the Pazzle Craftroom so can't use their files. look forward to seeing what you can do, Penny. I am not good with this type of thing either. tx
Bye for now,
Susan
[email protected] | www.susanbluerobot.com
I am an affiliate for Popup Card Studio™. If you are considering purchasing Popup Card Studio, please use this link and support my blog!
I am an affiliate for Make the Cut™. If you are considering purchasing Make the cut , please use this link and support my blog!
I am an affiliate of Scrap Factory™. if you are considering purchasing Scrap Factory , please use this link and support my blog!
Bye for now,
Susan
Bye for now,
Susan
You Know You're Gonna Have To Demo That On The Webinar?
happy to any time
Bye for now,
Susan
Bye for now,
Susan
Bye for now,
Susan
@SusanBluerobot...can't thank you enough for this file....what fun it was to make....
Hi MickyZs glad you had fun with the pattern .
Bye for now,
Susan
http://www.korthalsaltes.com/
There are tons of things on the left side of the page. Something has to be close
That one seems close. Try saying "Rhombicuboctahedron" 5 times fast.
or HERE
hope it helps
want to ask what the layer is for? i get the top/bottom and the score layer, but not sure about the third
