Is there a way?
nomemnomem Member Posts: 3,106
Is there a way to convert a file from Design Studio to MTC? I miss the "shadow" feature that comes with many Cricut cartridges.
Is there a way to move the cursor with the up/down/side arrow keys?
  • rachellann_714rachellann_714 Member Posts: 848
    There is a shadow feature in mtc. hold down the left mose button and drag it around your item then you should see a blue box of dashed lines go to edit then shape magic and sahadow layer this gives alayer slighly larger and solid if you want it larger pull that layer you just did way from the other item and do the same thing to it as you did before this gives alrger area of a shadow layer.
    Owner of a 24" Silver Bullet Professional Series, 18" Black cat Cougar, uscutters MH871, Bosskut gazelle. I can help with start up.  for the Cougar and Lynx and the Silver Bullet Professional Series. http://thatsscrapinc.com/ http://thymegraphics.co.uk/
    Nomem,
    There is a way. It is covered in the thread: "Before you buy another cartridge" here: http://make-the-cut.com/forum/comments.php?DiscussionID=430&page=1#Item_0
    HTH
    Jeanette
  • nomemnomem Member Posts: 3,106
    Thanks again for your help! I did it. I made two shadow layers, so I have three layers total. When I want to cut, should I put each layer in a separate file so that I can change paper color for each layer?
    edited January 2010
    Nomem,
    Check out this thread about making parts of your project invisible so you only cut what you want per page:
    http://make-the-cut.com/forum/comments.php?DiscussionID=764
    Also : http://make-the-cut.com/forum/comments.php?DiscussionID=613&page=1#Item_0
    You can also color each layer a different color to keep them straight, and lock them to show when they're invisible.
    HTH
    Jeanette
    Post edited by iggylover on
    You can put your paper in place on your mat the same as on the vurtual mat. That way you can cut all items at once.
    Check out stackyscraps newest mini-tutorial! (A Beginner's Overview) It covers so many of these little things in a quick, easy to understand video.
    Thank you Stacy!
    http://make-the-cut.com/forum/comments.php?DiscussionID=811&page=1#Item_2
    Jeanette
