Cocoa Mug Card
newMamawnewMamaw Member Posts: 174
Does anyone have a file of the mug card that a packet of hot cocoa slips into?
  • cmargmcmargm Member Posts: 658
    Here is a site that has one. Hope this is what you want.
    http://mommymelsaddiction.blogspot.com/2009/11/cocoa-or-coffee-mug-cards.html
  • newMamawnewMamaw Member Posts: 174
    Thanks cmargm, but I found this one and downloaded it but MTC won't open it. If I click on the file it's self it comes up that Windows need to know what program it was created in. Any suggestions? This is exactly what I want.
  • rachellann_714rachellann_714 Member Posts: 848
    Here's one I put together useing shapes from MTC basic shapes. will these work ?
    Rachellann
    Owner of a 24" Silver Bullet Professional Series, 18" Black cat Cougar, uscutters MH871, Bosskut gazelle. I can help with start up.  for the Cougar and Lynx and the Silver Bullet Professional Series. http://thatsscrapinc.com/ http://thymegraphics.co.uk/
  • mom6hsrmom6hsr Member Posts: 277
    rachellann,
    glad you uploaded that with the bottom tabs. I had one that I cut out by hand, yea, I know, but I only had a few to make at xmas time. You know what I ended up doing? I made a new one with a tab on the bottom!!! After I made about two, the bottoms being glued looked sloppy and homemade. so I added a couple of tabs at the bottom (it curved thus not just one tab), and stuck 2 sided tape on the tabs and the side tab and it was a much nicer look, nice and clean. then I added my packet of cocoa mix and my candy spoon I made. ( I started making candy years ago, to accent my cakes, so I just couldn't just dip, ya know ) :)
    Just another hint, if you do want to cut something out by hand :), cut it all a tad bit smaller and run it through a laminator machine and cut out. then trace and cut. I ended up using a punch to cut the inside of the handle out. I was NOT about to cut it out with a pair of scissors.
    They were will received.
    Sorry I didn't get back to you but the file I sent was with Sure Cuts Alot. Sorry, I didn't realize that. Here are a couple of SVG's that I have.
    here are the mug card in Mtc
