Cutting multiple pressures/materials in a single mat
jlaujlau Member Posts: 1
I have a Cricut maker and I would like to make two separate cuts on the same mat.  Each cut will have a different material and pressure.  I can't figure out how to do this other than sending the mat into the machine twice.  Is there a way to do it where I send the mat in only once?
    edited June 8
    @jlau Sorry didn't see you are using a Maker. Go to the Cricut website for detailed information on using your cutter with its software. Make The Cut! software does not support Cricut cutters.
