Mac or Windows
Hey guys im a newby today and just got my first cutter KNK MAXX
I havnt paid for Make The Cut yet because i am having trouble with both my mac and windows communicating with my computers.
My question is should i install it on my mac or on windows.
Chad
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,640
    I would suggest not to buy make the cut at all
    it is basically abandoned software
    and you may not get the registration key anyway
    It does not work with MAC
    I would suggest Sure Cut a Lot it it support you KNK Maxx cutter and it current support by it developer
    https://www.craftedge.com/download/
    there is a 14 day free trial available though it does watermark output in trail mode
    @Chado100 - another vote for do not buy Make The Cut! Sure Cuts A Lot (SCAL) is still be supported and developed by the developers, while Make The Cut! is abandoned. The pricing is actually better than the advertised price. There are great support groups through Facebook as well. If you like using a User Manual, there is one of those as well.
    https://www.iloveknk.com/0um/MaxxAir-with-SCAL/MaxxAir-with-SCAL-UM.pdf
    Also MTC does not work on a Mac if its got the latest OS. All Mac OS are not 64 bit, MTC is a 32 bit only program so it won't work.
  • Chado100Chado100 Member Posts: 7
    edited May 20
    I have downloaded SCAL 5 and still cant get this KNK MAXX to talk to my mac 10.15.7
    I have tried Bluetooth and USB all day
    Any ideas
    Post edited by Chado100 on
    @Chado100 - did you download the driver?
    https://knkusa.com/resources/
  • SandyMcCSandyMcC Member Posts: 7,887
    @Liz_A, do you see a Mac driver for a KNK there? I don't.  :(
    @Chado100, you SHOULD be able to get the following driver to work on your Mac.  Please use the following instructions:
    (1) Unplug your USB cable if you have it plugged into your computer.
    (2) Go to this link, scroll down to the table
    (3) On the row with the newer Mac O/S listed, click on 2.4.4.  Download and run that file.
    (4) After running that file, reboot your computer and wait for your Mac to fully come back up.
    (5) Then connect the USB cable to your computer, turn on the cutter, and wait like 15 seconds or so.
    (6) Open SCAL, go to the Cut Settings window, click on the refresh icon (to the left of Test Connection).
    (7) Click on Test Connection and the cutter head should do a small jog back and forth.
    @SandyMcC - no I didn't even think Mac, LOL! Looks like it is just a PC only version.
    edited May 21
    Still nothing.
    is the usb cord the same as a printer cord??
    I have now downloaded SCAL on my windows machine and it dont work either
  • hxxxopehxxxope Member Posts: 2
    try Bluetooth?
    Bluetooth does not work either.
    Test button on the machine works
    Im ready to throw it in the bin and buy a cricut or something
  • MeFlickMeFlick Member Posts: 9,315
    Where did you get your KNK Maxx? Did you Buy it used from someone? I ask because the KNK Maxx cutters were I thought, no longer available new. I also ask because if it is used, there might be more at play with your issues. You also don’t indicate that you have done exactly the 7 steps @SandyMcC outlined above. Sandy was THE person who wrote the manuals for SCAL and the KNK cutters and provided years of support so she is the person who knows how to help you but you have to follow what she is asking and report back so she can help you troubleshoot. She is in AZ in USA so depending on where you are, there may be significant time differences so you would need to be patient.
    Somehow I missed the fact you have Windows available. It's MUCH easier to get an older cutter, like the Maxx, working with Windows.  Using similar (but NOT identical), try the following, step by step. And yes, you can use a printer USB cable just in case that might be the issue:
    (3) On the far right side you'll see "setup executable"... click on that link, download, extract, and run it.
    (4) After running that file, reboot Windows and wait for Windows to fully come back up.
    (8) If you still get no response, right click on the Windows Start button and select Device Manager.  Look for a Ports folder and report back what it shows inside. If there is no Ports folder, look for any listing of an Unknown Device in the Device Manager menu and report that.
    Would also be beneficial to know what OS you are running on your computer(s) you are trying to use. For example, if older windows version, there was one (seems like 7 maybe 🤔) that was notorious for blocking the download and install of drivers. If newest on Mac, you definitely could no longer run MTC because MAC no longer supports 32 bit programs. So even little details like that matter in trying to help you.
    edited May 22
    I have tried everything suggested.
    I am running windows 10 and macOS Catalina 10.15.7
    Ports (Com & LPT)
    ECP printer port (LP1)
    standard serial over bluetooth link (com4)
    standard serial over bluetooth link (com5)
    It appears that the USB port on the Maxx may not be functional.  But it does appear that something is connected via Bluetooth. Is your Maxx a Maxx Air model?  The original Maxx doesn't have Bluetooth capability. And, if this is a Maxx Air model you MUST have Maxx Air selected in SCAL if any connectivity is to be successful.
    In other words, IF this is a Maxx model, then this is what you would want set. If you're not sure if you have a Maxx or a Maxx Air, then on the control panel, press the menu button repeatedly and count how many screens you see. PLEASE do not change any settings as you progress through those screens... not yet. For now, just count them.  The original Maxx has only like 3, I believe. The Maxx has like 6 or 7.
    It only says KNK MAXX and the machine is black in colour.
    I have tried both with both computers.
    Anyway i spoke to the person i bought it off and i will take it back.
    I have gone and bought a Cricut Maker and its going great guns and easy to use and set up.
    Thank you for all your help guys.
    The color and the vinyl sticker do not mean anything. That's why I didn't ask for that. I needed an actual "test" that would indicate one way or the other if it was a Maxx or a Maxx Air.
