Appreciate The Help!
I just cut my first rhinestone template with SGS Rhinestone Template Material Roll, and I used what silouette automatically set for the settings. They were Cut 5, Force 5, Speed 33, double cut also. It cut the sides a little but the holes weren’t cut at all, and all you see are indentations of holes. Are the settings wrong?..What does everyone else use? Really appreciate the help, I’m so frustrated because I cut a design from heat transfer neon glitter, and it cut perfectly!
    @Fancyface - welcome to the Make The Cut! software forum where we support the software Make The Cut! and its supported cutters. The newer Silhouettes are not supported, so I am assuming you are using the Silhouette software. Your best option is contact Silhouette America for their expert guidance.
  • FancyfaceFancyface Member Posts: 2
    Yes I use silouette business edition. Thank you!..:)
