Draw and cut. Will draw but gets stuck on the cut.x
My cricutmaker is failing to cut when I draw prior to the cut. If I foil and cut it works. It will print and cut snd do ordinary cuts. As soon as I put a cricut pen in it will draw but not cut. It will say the blade is stuck and to clean cutting area. I have done this and changed the blade. Still.no good. Help please.
  • MeFlickMeFlick Member Posts: 9,299
    Welcome to the Make the Cut software support forum. MTC does not work with the Cricut line of cutters so I assume you are working with their program. You will get the best and quickest help through Cricut user Facebook groups, of which there are many. Unfortunately Provocraft did away with their support forum years ago.
  • Liz_ALiz_A Member Posts: 10,842
    @Pavlena - welcome to the Make The Cut! software forum where we support the software Make The Cut! and its supported cutters. Your cutter is not supported so you will be using the DS software.
    Make sure you have the cricut pen in the correct holder. Make sure that what you want cut is marked as a cut in the screen before you Make it.
