I have just bought a Portrait 3, specifically for Vinyl and its amazing..
I am looking to see what else I can do with it and Mattless "Pop-Out" cutting is appealing, but I can't find the option
I have followed the manual (and set Cutting Mat to NONE) but Pop-Out Cuts does not appear as an Action..
Here is a video of what I am doing
To me this just looks like an oversight in the software as I know the feature is supported.. Has anyone else manage to get Pop-Out cutting to work on a Portrait 3
Contact your seller, or Silhouette America directly:
https://www.silhouetteamerica.com/contact
- Make sure you have chosen the correct cutter
- Make sure you are using AutoBlade (the cutter has to detect it, I believe)
I think the issue is that you must use the AutoBlade, and the cutter and the autoblade must be detected for those options to be available.
Maybe most importantly, PUT SOMETHING on the mat to cut!!!
First of all, as Liz stated, check your Silh Studio version number and make sure you're on the latest.
Next, on the Design tab, set Cutting Mat to None.
Insert your cardstock into the cutter.
With the AutoBlade mounted, click on the Send tab and select Cardstock, Plain (for now as a test).
The Action should change to Auto (Pop-out card) automatically. It does for me with Portrait selected as the cutter. On the other hand, the Silhouettes are a bit too "smart" and it could be saying to me, "I don't care if you have Portrait selected, you're connected to a Cameo 4." lol
Jon
Otherwise, I would say you either have a defective AutoBlade or a defective cutter.
