I'm using Make the Cut with a KNK Zing. I've printed the registration marks but the cutter keeps starting the cuts past the registration mark. In the attached picture, you can the registration mark should stop mid-center of the black line. The cutter is cutting the shape the right dimensions, but because it starts the cut past the registration mark, everything is offset. What is going wrong here? Why would it even try cutting past the set registration marks?
If you HAVE calibrated the Zing and you're still using the same installation of MTC on this computer, then the next question is this: Are you changing the Show/Hide properties of any layers after printing and before cutting?
I'm now trying to understand what I'm seeing in your photo. It looks like there's a printed image touching your reg mark?
The second thing is to make sure there is nothing sticky that can throw off the accuracy. Make sure the pinch wheels and the grit shafts beneath appear to be very clean, as well as the underside of the cutting mat. Also, load the mat so that you have pinch wheels about the same distance from the outside.
