I PULLED OUT THE USB CONNECTION FROM COMPUTER WONT WORK NOW
MACHINE WAS WORKING FINE...I PULLED OUT THE USB CONNECTION FROM COMPUTER  TO USE FOR SOMETHING ELSE
WHEN I THEN WENT BACK TO MTC PROGRAM EVERYTHING WORKS EXCEPT TO CUT  IUSE THE ARROWS TOSET UP MAT
PULLED OUT EVERYTHING AND PLUGGED BACK IN AND STILL WONT WORK   EILEEN LEBER
  • Liz_ALiz_A Member Posts: 10,904
    @neelie - first off, we need to know what cutter are you using, and what version of Make The Cut!
    Try totally shutting down the computer. Wait 10 minutes. Now plug the cutter back into the same USB port it was connected to. Power on the cutter. Power on the computer. Try MTC. In MTC make sure that the right USB port is chosen in the Cut with cutter... options.
