Print and Cut Contour (Shadow) weld?
Read the PDF on adding a contour to an image. It says to weld the image and the shadow layer. When I weld them and look at print preview...no shadow layer. If I DON'T weld, and just delete the image layer, at cutting, all is well. Am I missing something?
A grandma's name is little less in love than is the doting title of a mother. -- William Shakespeare
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,638
    edited September 2020
    is the bottom image the result your wanting ? black colored shadow
    weld you join or weld object the attributes of the upper most object in the layer stack
    so the shadow adopts the fill of the trace which is the image and also because the shadow is larger the no colour mask surrounding it
    Instead of doing weld
    Select both objects and try texture snap shot
    result will vary depend on how good the trace is
    the other method would be print with the trace and shadow visible then hide the trace layer before cutting
  • DreamStreetRoseDreamStreetRose Member Posts: 242
    Yes, it is.
    And I will try the 'texture snapshot'
    Thanks so much! 😉
