CRICUT MAKER - cutting heavy chipboard help
mrt33mrt33 Member Posts: 1
Hi everyone, I just purchased a knife blade with intentions of cutting some heavy chipboard (cricut brand 2.0mm heavy chipboard) but i'm running into an issue. My project is 8.621x10.5, when I select 'make it' - design space does not recognize heavy chipboard as a compatible material, only light chipboard. What am I doing wrong?
    @mrt33 - well if you can't choose heavy chipboard, then that's a program limitation. My first instinct is to say, buy another cutter that isn't so limited, but some people might not like that, LOL!!!
    So choose the heaviest material on the list, reduce the speed and increased the number of passes. Know that you will likely NOT be able to get very detailed cuts from this material.
    Additionally find a Cricut specific forum...this one is for the SOFTWARE Make The Cut! and its supported cutters. Cricuts are not supported!
