Steel rule dies with crease pad
jazzyladyjazzylady Member Posts: 86
I have a Big Shot Plus die cutting machine.  I have recently purchased some Spellbinders steel rule dies.
A couple of the dies are CUTTING some of the CREASE lines.
I am using a crease pad. (I have even tried using a crease pad at the top & bottom).
I have had this problem before & have resolved it by permanently placing a couple of pieces of painters tape, scotch tape or craft foam over the affected crease lines.
Sadly, this tip not working for these particular dies.  I can see that the blades in the affected area are not as recessed as they should be.
I would welcome any suggestion that anyone may have to resolve this issue.
Thank you in advance for any tips or tricks
    @jazzylady - sorry I do not use this brand of product at all, no help here. I would contact either the manufacturer or if they have one, a forum of users.
