Silhouette Cameo 4 problem
tijsje1997tijsje1997 Member Posts: 2
edited November 2020 in Off Topic
Hello people! :)
A few weeks ago i bought the Silhouette Cameo 4.
From the beginning I had the idea that it was not cutting correctly.
I am cutting the Oracal 951 and Oracal 751 C and i have this problem with both vinyls.
As u can see in the picture the vinyl got damaged. I tried multiple settings on the Cameo, and i could not find an solution...
Could u people maybe help me? Thank you!
Pictures above and below!
  • Liz_ALiz_A Member Posts: 10,904
    @tijsje1997 - welcome to the Make The Cut! software forum, where we support the software Make The Cut! and its supported cutters. The Cameo 4 cutters are not fully supported, and it appears that you are using Silhouette Studio not Make The Cut!.
    Are you using the ratchet blade holder or some other blade holder?
    Have you looked at the blade holder to see if some small pieces of the vinyl have managed to get up inside the blade holder?
    Have you chosen the correct material? My list of materials in English includes Oracal 651. Do you have this on your list?
  • tijsje1997tijsje1997 Member Posts: 2
    Thanks for your reaction!
    I am using the autoblade, I checked if there was any vinyl inside. But I did not find anything...
    I am using the Oracal 751C and Oracal 951!
    @tijsje1997 - you are welcome!
    So I would start by only doing test cuts with a small shape like a donut (circle with a hole in it). That way you can lift out the hole and check to see how the cut goes.
    You can also make custom changes to the settings for vinyl - in Material Settings (you'll have to figure out what that is in your language (Dutch?)) - that you are cutting. Maybe slightly increase the blade depth (but be careful not to cut through the backing) and maybe do 2 passes. Your speed seems to be ok. Then save the setting and test with the test shape (donut). Make more changes until your test shape is perfect! Now try your file.
  • llahammellahamme Member Posts: 1
    I'm having exactly the same problem - it just doesn't cut perfectly. I have 3 machines, the portrait and the original cameo cut perfectly every time but when I use the 4 it's like it slips ever so slightly. The lever is fully down, I have tried changing to the ratchet blade, the blade is installed correctly, and still it's the same. I can't even cut a basic shape perfectly! Please help!
  • SandyMcCSandyMcC Member Posts: 7,861
    @llahamme ,  First of all, in order for the pinch wheels to be down, the lever needs to be in the UP position, not "fully down" as you stated.  So, please check that first.
    If you mean to type "fully up", then what material are you cutting? Are you using the cutting mat or cutting, say, vinyl without a mat?  If it's the latter, what is the width of the vinyl?
    And are you using the default cut settings for that material?
  • Service on Wheel is the leading service center for plumbing, carpenter, electricians, microwave, refrigerator, AC and washing machine in India.
    Website ;- https://www.serviceonwheel.com/
  • czjewellery22czjewellery22 Member Posts: 1
    Kanhai Jewels is Mumbai based company established in 2001, We are manufacturer and wholesaler of Indian Jewellery and Western trendy jewellery, as well as Exporters of Traditional Indian Jewellery.Our Strength is the wide range of products in which we deal like Antique Jewellery, KundanJewellery, American Diamond (CZ) Jewellery, PolkiJewellery, Meena work Jewellery, temple jewellery, thewajewellery and Western Jewellery
    website: https://www.kanhaijewels.com/category/imitation-jewellery
