Hi Everyone,
I have a box project that I downloaded for free. It as dashed score lines on it. My Maker will score each dashed line. I want to convert it over to 1 long line so I can use the scoring wheel. I ungroup everything but the dashed lines stay complete. Is there a way to convert without redrawing a score lines overtop? I tried Inkscape but not that good with it.
Any help would be appreciated.
Thank you
0 ·
It might be that rather than the dash line be a single line with a dashed adtribute it is a series of separate single lines
If so>
if is a svg file it probably going to be easier to open the file in inkscape (free) or corel/ adobe illustrator if you have it
and edit the line - either joining the dashed paths together - extending one of the line and deleting the rest
I'm not that familiar with DS
but you could try this
determine the length the line needs to be
delete all but the dash at the beginning of the line (guessing--- the top for vertical line and left for horizontal)
resize the dash to the length previously determined
( you might also have move position depending where the starting point was
Thanks for the advice though.
Doing this in DS is horrible at best.
