cricuit explorer air 2
friesenannyfriesenanny Member Posts: 1
Yes my cricuit explorer air 2 was doing on draw and cut not it will not cut when I do the draw images. How can this be fixed?
  • Liz_ALiz_A Member Posts: 10,892
    @friesenanny - welcome to the Make The Cut! software support forum, where we support users of the software Make The Cut! and its supported cutters. Your cutter is not supported, and I am confident you are not even using Make The Cut! as Cricut cutters are not supported.
    You need to contact Cricut and get help from them or other more experienced users. You need to learn how to use the software that does work with your cutter - Design Space. Start here:
    http://learn.cricut.com/
    https://learn.cricut.com/design-space-for-beginners
    A cutter is only as good as the software that runs it, so if you don't know the software your cutter is pretty much like an unused tool in the shed. Have fun learning.
