Printer frame on mat won't go away
RainRain Member Posts: 46
This printer frame on my mat won't go away.  This is the first time I've used MTC on this computer in forever.  I've never seen this before.  Can you please tell me how to make the printer frame go away??
Thanks!
  • MeFlickMeFlick Member Posts: 9,301
    Go to File Menu, select Print Options, click on (uncheck) the "Show Paper on Mat," click on "OK' - should be removed from mat on screen.
  • Liz_ALiz_A Member Posts: 10,904
    It's a toggle and you're in control of it, so either it shows or it does not show, the default setting is that it does not show, and that jives with why you haven't seen it. However, you did turn it on, maybe inadvertently, but you did turn it on =). So when unexpected things just turn up, you just need to backtrack and ask yourself, what have I done the last few steps! =)
  • RainRain Member Posts: 46
    @MeFlick that worked perfectly!  Thank you so much!
    @Liz_A I have no doubt that I caused it, I just couldn't figure out how to undo it!  Lol  Thanks for your help!
    You're welcome.
