plug in for Cameo 4
Im trying to cut to Cameo 4 MTC does not see new cutter do I need new update to send to new cutter?
  • bballmombballmom Member Posts: 4
    I updated MTC restarted my computer and cutter came up Im able to cut.
  • Liz_ALiz_A Member Posts: 11,010
    @bballmom - MTC does not fully support the newer Cameo cutters. You will get basic cutting only and no support for the second blade assembly at all. I would strongly recommend if you are not using Silhouette Studio (which I suggest that you do) then purchase Sure Cuts A Lot (SCAL) as it supports Cameo 4 and it is being actively supported by the developer.
