Is Make the Cut Software compatible with MAC IOS
Teekay24Teekay24 Member Posts: 1
Is Make the Cut Software compatible with MAC IOS?
Best Answers
  • MeFlickMeFlick Posts: 9,241
    Accepted Answer
    1. Short answer is “it depends.” It depends on several things, what operating system version you are on (most recent update to Catalina no) as well as what cutter you use. The Mac version only worked with a limited number of cutter brands, the earlier KNK models and the Blact Cat and Silver Bullet lines. You can partition your Mac and put Windows on it and then run MTC and other cutters from it.
    See this recent thread: https://forum.make-the-cut.com/discussion/46857/macbook-compatibility#latest
    however, also note - MTC is basically an abandoned program that has not been updated in YEARS now so is also not compatible with many of the new cutters on the market. It is still a great program and. An be used with older cutters and to export files out to SVG files that can be imported into other programs.
  • Liz_ALiz_A Posts: 10,504
    Accepted Answer
    @Teekay24 - once you have updated to Catalina, definitely not, as MTC is a 32 bit program and from version Catalina on, Macs will only support 64 bit. You are better off to look into SCAL - which has a native Mac version that is supported on 64 bit operating systems.
    http://craftedge.com/
