Importing Textures or patterns - RESOLVED
jazzyladyjazzylady Member Posts: 86
edited December 2019 in Help for Make The Cut
Hello fellow MTC users
When I import a texture or pattern into a shape it is not centered or positioned as I would like.
Is it possible to reposition the imported texture?
If it is not possible in MTC is it possible with SCAL 5?  (Which I purchased this week but have not
had much of an opportunity familiarize myself with it.)
Thank you for any input you may have.
Post edited by jazzylady on
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,639
    Positioning texture using the Texture offset setting can be a little tricky
    The method i use is
    Using trace function pixel treshold 255 and texturise path enabled
    position this texture shape above the shape you which to add texture to
    select both the texture and the shape
    Join
    Break
    The shape should have now taken on the texture
    Scal has a Pattern Fill feature which includes a preview function
    which positioning the pattern does seem easier
  • jazzyladyjazzylady Member Posts: 86
    Crazy_Mr_Zing  Thank you sooooooooooooooo much.  – It worked like a charm.
     I have been struggling with this for over a week.
     It never occurred to me to ask on the forum until today.
    (Despite the fact that I check in on the forum most days)
     Nice to know that there is still some support here.
     Thank you to all those that offer support & post files.
