Zing Air Laser
I was just finishing my Thanksgiving cards when the minute I hit CUT (after setting the laser point) the blade shifted back to the right and the laser went off....no cutting!  I have verified the machine is connected and is cutting with Zing Air turned the machine and the software on and off.  Oh NO what is the problem???
  • CharoCharo Member Posts: 768
    I found an old post in MTC on this issue and re-downloaded the plugin.  Then I was able to cut a simple shape.  This one still won't cut so I guess it is the file but I don't now why.  I enlarged and don't see any strange things and it is one of Di's decorative braces, except the words of course, and she never makes errors! It is the shape on first layer that won't cut.
  • Liz_ALiz_A Member Posts: 10,843
    @Charo - the file is quite large (for an MTC file) because you have the graphics in the background.
    Try copying the layer and then put it into a new empty MTC file and cutting from there. Close this file first before trying.
    PS - Charo - there are over 22,000 nodes in those 4 images, so that may be the problem as well. Try the Smooth & Simplify to get the numbers down.
    Restart the computer as well, its likely not enough resources that is an issue as well.
    @Liz_A I saw all those nodes and tried all your suggestions:  that shape will not print for me.  It's OK I'll choose another shape.  That many nodes aren't worth borthering with!  Thanks for your help.
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,638
    not quite sure i understand "that shape will not print for me"
    I assume you mean this shape
    did you try auto simplify path
    often also using flatten paths will help you pattern the pose cutting issues
    I think it was the text that was used that is causing that issue, just a hunch. I used a text similar to that one time and my MTC would just close. Used a different font and no worries.
    @Liz_A Yes I did try all those things.  I even thought it might be the text but working with words is my least favorite thing in paper crafting so I decided it wasn't worth the effort and scrapped it for something much easier.  That text style wasn't the best for the purpose anyway....just hate trying to find a font I like.
