slicing a circle what am I doing wrong? [Resolved]
Sarahsmom85Sarahsmom85 Member Posts: 69
edited December 2015 in Resolved Issues
I am hoping this is an easy fix. I am trying to slice a Mickey head, to make it look like it has shorts. I am using the draw bezier tool, I am holding against the edge and right click and then go to the other edge and left click to make the line but it doesn't cut it make a line that is not connected. what do I need to do? to cut it in half?
    @Sarahsmom85 use the Slice shapes tool tool at the bottom, second from last. The one you are using draws shapes not cuts them.
    You would not use the bezier tool to slice something in half to separate it. That tool simply draws a line or connects two open nodes with a line. In order to "slice" an object like you are wanting, you could use either the knife tool or the eraser tool. I would use the knife tool.
  • Sarahsmom85Sarahsmom85 Member Posts: 69
    when I use the knife it does slice it now I have to close it. what tool do I use to do that. Sorry I have had this for a long time but I most cut pre cut items.
    never mind I got it. Thanks
    Glad you got it figured out, sorry I didn't explain that part. Assumed you would know I guess. Will add for others who might not know, once you split with the knife, you separate the two sections apart then you would use the bezier tool to close the shape by putting your new line between your open nodes.
    For more specific details and help in learning the node editing tools like the bezier tool, knife tool, and others I recommend that users be sure to check out the manual. It can be accessed From within Make The Cut, if you go to Help > Instruction and Tutorials. That will bring up a web page with links to the manual.
  • Calgalcre8sCalgalcre8s Member Posts: 2,901
    For anyone else who may not know where the Slice shapes tool is located, here is a visual:
    I would have used the rubber set at thin to cut the two parts as it would also close the cuts in one move!! It's immediately above the knife and a very clever tool if you use the correct settings for it. Check the manual out and videos in it.
