This paper sculpturing is insane. I can't even fathom how the artist creates this:
Over 90 free MTC videos:
http://www.iloveknk.com/support/mtc-support/Latest MTC User Manuals:
http://www.iloveknk.com/Support/user-manuals/
But you actually have not seen it all......try this one....the ultimate 3D print and cut machine that uses regular office copy paper and an Epson color printer with special ink and then the cut machine that also applies glue. Post processing time needed to weed it.
Etsy | Mugs For U
Next the file is sent to a 3D printer that moves layers of paper into the cutter. After the cut is made a nozzle applies glue at the appropriate locations before the next layer is added. When the whole stack of layers is finished it gets weeded to reveal the sculpture.
Just think of it as print and cut functions that keep stacking layers of bond paper up and up and up with each layer having a slightly different outline cut than the layer above and below it because that is basically how it is done.
You could actually build something like this yourself on a much simpler scale with hand applied glue. On your cutting pattern put registration holes in the same locations (corners?) of each of your paper sheets and drop the layers down over pegs in a board below so they all line up perfectly. You will have to leave some tabs along the cut edges to hold it all together then cut the tabs as you weed. You would gently brayer down each layer where the glue is applied as you add it on top of the one below. I would suggest making square holes and and using square pegs as it is more difficult to cut accurate circles on the drag knife machines.
http://www.thisiscolossal.com/2013/01/stained-glass-windows-made-from-laser-cut-paper-by-eric-standley/
Etsy | Mugs For U
