Having issues with Text on PCS
Help!!! When I bring in text onto the PCS mat, the letters are all lying back. How can I get them to come in up right? TIA
    Are you on the vertical plane or the horizontal plane? Are you looking at the "cut outs" of the text shapes instead of the shapes themselves? Can you post a screen shot of what you are talking about?
    @Calgalcr8s do you mean like this the letters are on the plane and you get the shaddow on the bottom ? that is fine that is what is going to cut out of the card
  • Calgalcre8sCalgalcre8s Member Posts: 2,901
    @SBryanW.... Here is the file. I am following Susan's video to practice and learn this software.
    edited February 2014
    @Calgalcr8s - They are lying "flat" because you are on a plane that has the Edit Side of Bottom. For those you want to be on a plane that has an Edit Side of Back. You can switch between the two edit sides by pressing your space bar key. Select the text, do a cut (Ctrl+X), press the space bar and set the plane to the position you want, and then do a paste (Ctrl+V).
