help - I can't seem to cut off a tiny bit - resolved
JustlauryJustlaury Member Posts: 508
edited January 2014 in Help for Popup Card Studio
The file and a picture of the piece I want to cut off is attached. I was able to get rid of the the bits and pieces from the bottom section using @susanbluerobot 's video instructions. but I just can't seem to make it work for the top tiny pieces.
Suggestions?image
@andy @sbryanW
Post edited by Justlaury on
    it's more-or-less a bug... even if you lay a shape over the top of them, they will still be fold lines instead of cut lines. I will see if I can't fix it in the next version.
    a lot of the time you'd want to keep those "tabs" as they add stability to the card when you glue a backing to it
