Main Bar Disappears!
This keeps happening. I will click somewhere close or on it, and it just goes away. The layers bar is there, I have tried everything, I do not want to again reload the software.
I have mac Os x 10.6 Yes, under view, it is checked... I have un and re, I have opened other saved files, I can close and reopen the layers bar just fine. Anyone have this problem?
Thanks Bill
  • SandyMcCSandyMcC Member Posts: 7,698
    I just tried to make it happy on my Mac and I can't. In fact, I can only close it and open it. On a PC, I can resize it and move it. The same is true of the Layer Bar. So, I'm not sure what's up.
    Let's see if @MeFlick can tell us anything. She has a lot more experience using the Mac version.
  • MeFlickMeFlick Member Posts: 9,256
    I will have to check here in a little bit on my Mac. I don't recall having had this problem. It will be just a little bit before I can check it though.
    Ok Bill, I finally had a chance to sit down on my MacBook Pro laptop. It has OSX 10.7.5 on it. I played around with it and I am attaching a screen shot that I have added some notes and information to. Review it and see what you think. I think that you are clicking on the little x in the top right corner of the menu bar to close it out; then when you go to view and click to check it back on, the menu bar is coming up at the very bottom under the layer bar. I tried to get a screen capture of the little double headed arrow the curser will change to if you hover there but couldn't. If you hover there and get the curser line change like I am referring to you should be able to click and pull up and find the menu bar area again. You shouldn't need to uninstall and reinstall the software.
    That all said, I didn't consistently get that to happen where the menu bar showed up barely at the bottom versus the top. I cannot get it consistent to say when exactly it occurs. I think it has something to do with the size of the areas, and which is closed and opened first or last.
