DXF import and export
charlieyeh1215charlieyeh1215 Member Posts: 1
edited March 2012 in Wishlist!
since i use Autocad to draw engineering designs, it would be great if you guys add dxf import/export support. DXF is one of the most widely used formats for CAD drawing, this would allow me to design with Rhino3D too.
  • SawdustSawdust Member Posts: 306
    Hi Charlie, I use Qcad, it has the ability to export as svg. There is also an online converter that allows you to switch back and forth between formats. And yes, would be handy if it was built right in.
