I just bought the font smoothline and when I do text in MTC it does not look like it does in other programs, has white spots and is not smooth. How do you get the font to look smoother. Thanks for any input Mary
Add the letters individually to the mat by choosing Split by Glyph in the option box under No Splitting. Select all the letters, and choose Weld. This should join them all together with no gaps. Without a split they are joined using Join which will leave the gaps where intersections occur. Weld does not behave that way.
Takinga little stab in the dark is this the sort of thing you mean by white spots
try using split by glyphs then weld
