Help! How to make thick lines for a stencil/template
Hello everyone! I need help with figuring out how to make lines thick in order to cut a stencil/template for a quilting block. The lines are dashed so that each shape is not completely cut out of the material (mylar). In MTC these lines are too thin and do not cut the width I need. After cutting, I need to be able to slide a fine point marker in the cut grooves so that I can trace this template onto my fabric for placement of applique pieces. I cannot find how to convert thin lines into thicker ones on MTC and still keep the dashed lines. Can this be done in MTC? Thank you in advance for your help. I have attached the file I am working on just in case my explanation is confusing. Thank you, Lisa M.
I understand what you want to do - but shadow won't do it as it loses the line breaks. The only thing I can think of is that you save the part that you want to thicken as a png and then re-trace in which will give you broken lines instead of dash lines and then use the shadow feature to increase their thickness. A bit long winded but that it is what I would do in these circumstances. If you want it done for you I'm more then happy to do it but I'm guessing you want to be able to do it yourself.
This is quite a puzzle If you pixel traced I wonder why that does not show as a cached image in this file tracing line art usually results in double paths
Hi, Sorry, I should have explained that after I scanned the image, I changed the lines to dashed in MTC. This is why the lines appear that way in MTC. I need the space in between so that the whole shape doesn't come apart. Here are two of the images I scanned. Thank you so much for your help. --Lisa
As Leslie suggested creating a shadow of a path would effective create a fatter But I think when you shadow a dashed line creates shadow of the whole path not one for each dash
I think I would change the line style back to no dashes
make the paths open
Create shadows of the paths and then use the eraser to make the gaps
The advantage of shadowing a open path is a shadow of a open path surrounds the path like this
So you original path will be in the centre of the shadow
I cheated - I changed your lines in your original MTC into straight lines and exported as an svg and then imported into Serif and thickened the lines of the first star and then dashed them and then exported as a png and traced back into MTC - this was the only way I could see to do this. If you want the other pages converted I can do it for you but it doesn't solve you for doing it for yourself.
Hello everyone! Thank you so much for helping me! I am going to try to replicate on my computer this morning how you made the stencils out of the scans. This community is the best! Thank you for this forum.
--Lisa
are you able to share the image you scanned ?
--Lisa
make the paths open
you can then hide or discard the original paths
then use the eraser to create the gaps
Thank you.
--Lisa
