I was watching how to do pop up with blue robot.i followed her to point when she moved the grid up to anchor her tree.But could not see how she moved the grid i have had this programe since it came out and never mastered it so thought i would sit down and try.got lost at the grid move.Any help please appreciated thank you ....Maz
Holding the control/shift down and move the roll wheel on you mouse
Hold Shift and Press Up or Down Arrows on the keyboard to move the distance set in Snaping
Pam
With a mouse its much the same as MTC left click on the shape and you will get the red arrows to rotate , skew or resize
you might have to zoom in to see them
You can do it with the mouse pad on the laptop left click on the red arrow and drag you finger . it a little tricky
I've never used a drawing pad so not sure how that translates
PCS also has a default rotate by degrees in program preference if you hold ALT while dragging the rotation will snap by the degree setting
not sure which video your referring to
