Three 3D Popup Stair Cards (Updated with another design, (again!))
AndyAndy Administrator Posts: 4,579
edited April 2013 in Your Masterpieces
I have been on a popup card kick... I found this image on the internet:
And thought that I could recreate that in Make The Cut. So, I set my Snap Position to 1/8" and just started drawing lines. Once you get the first staircase done, it's just a lot of repeating.
That was the easy part... The *hard* part is folding it so it looks right! Either way -- it looks COOL in real life.
You need to cut it out on 100+ lb. cardstock. I used 110 lb printer card stock and it worked perfectly. The MTC file I made is attached for all to use. It's not 100% exactly like the original one -- only because i wanted it to fit on 8.5x11 paper.
Here are some pics of the one I cut out...
MTC file attached at the bottom of this post.
Have fun with this!
-andy.
Post edited by Andy on
I don't often test my code... But when I do, I do it in production.
«1
