I had a few requests last week. Let me know what you think. As always, if you have any suggestions or requests let me know and I will see what I can do.
I was one who requested Steven Tyler -you did an absolutely AMAZING job! It is just FABULOUS! You REALLY need to consider doing a tutorial on how you do this - would love to do on some family type photos! You are so talented!!!!!!
In the next couple months, I want to have a series of videos done to teach everyone how to make their own paper portraits. It is not an easy process, but can be taught with someone who has patience to learn it.
You kidding. I currently have a 12" cutter and I'm ready to go big! That's why I want a 24' inch Cougar. My goal is to raise the funds to afford one and make large scale art pieces. I have all ready started learning how to make my own homemade paper so I can have custom colors to fit a 24" mat.
Greg, you are thinking big. Good for you. I'm like K_lee, just want to learn the process so I can do some of my family. Thank you for considering teaching us how to do it. It will be so great if it can be cut with MTC.
Using MTC to cut is not the issue. It is designing it for MTC users. You create vector images right in the Pazzles Inspiration software. MTC users have to use other software to do this. From what I can tell from the forums, people use Inkscape for this feature. So, I have to look into the Inkscape software. Hopefully, it won't be that hard to learn.
Shirltop, I took the liberty of posterizing the image of your granddaughter. I have it set at 5 layers. This is just an example of what it could look like without editing the image before hand. A little tinkering with it could improve the quality before preparing the vector files for cutting.
I'm glad you liked it. It is set to be an 8x10. Here are the individual layers. Consider it a belated Xmas gift. Start with layer5 and work up to layer1. All you have to do now is pixel trace in MTC and your ready to go. I recommend using Bazzill Monochromatic packs. It will make choosing your paper simple. The only tricky layer will be layer2. Overall, I kept it simple to use it as a demonstration on how the process works. If you have any questions, please feel free to contact me. If you make it, upload the image. I would love to see it completed.
I hope this helps everyone understand my process of making Paper Portraits. I plan on making the training tutorials in the next month or two.
Paperkutz, With the way you do the posterizing, it is relatively easy to do pixel traces in MTC for each layer without having to split the picture into individual layer images first - especially because of the way the final paper piecing is assembled (lightest layer on the bottom). Last night I took your test9.jpg image you posted above and did a pixel trace on it five times, setting the threshold level different for each. It took only a couple of minutes to do the whole thing. If you always used the same levels of gray when posterizing and recorded which threshold level went with each color, it would go even faster. Here is the resulting MTC file I came up with (I enlarged it once I got it into MTC, but you can see the layers are pretty close to the layerN.jpg images above).
Wow you guys! These are amazing! Thank you Paperkutz for the late Christmas present! Thank you Paperkutz, Bryan and Rachellann for all the help! Now to find the time to get this cut and see how I do! Thank you, thank you, thank you again and again!
Bryan, excellent work. I haven't compared threshold levels on a range of portraits, but your theory of standard threshold levels on the same gray scale posterizing sounds solid. I will experiment with this. When I create the video tutorial, I will make sure to incorporate turning the picture gray scale before posterizing and then the standard threshold levels we predetermined will make this a super simple process.
Rachellann, your correct, but I choose to posterize before going to MTC. This allows for better control of the detail in the image. I'm still experimenting with light, dark and midtone settings to create the best posterized image before going to MTC for the cut files to be created.
The cadlink software that comes with the Klic N Kut will do those things you are looking for. It has a pretty powerful scanning tool and editing capabilities. I can import low resolution images from the web and get a pretty clean scan, as well as posterizing the image as necessary.
MTC will also run the KNK. I am using both with it now.
Rachellann, Great job! I can't wait to see more of them.
Thank you the colors were not what i wanted but finding the ones i wanted and had on hand was two different thingsI really wanted to do it by using papers that were two to three shades darker than the next.
I love your paper portraits. I tried to do one of my daughter and I brought the photo into Photo Shop Elements 9 and I used the magic lasso to cut out her image. Then I turned it into a black and white image and then posterized it. After that I can't figure out how to separate the layers into different shades. Do I just save the image and then trace it into MTC? Thank you. Also my posterized image is quite as detailed as yours or Bryan's.
*** 24 Inch Black Cat Cougar For Sale – SOLD
*** Silhouette SD For Sale - Please PM me if interested ***
Yes, save it and take the image to MTC. You will start with the lightest (farthest) back layer and pixel trace. The next layer you adjust your threshold to select the next shade and so on. Good thinking with the magic lasso. Sometimes the background is way too busy to use and you need a clean background.
Since your using Elements, you may want to clean up the image after posterizing. Use the eye dropper to select the color and paint over certain areas that need adjusting before going to MTC to make your cut files.
Amazing work on the portraits!!! I am really wanting to learn this so I can do it too!!! Can't wait for webinar on this; please make sure you send me info when you do this. Don't want to miss out! This is one of my favorite things I want to be able to do. My grand-daughter and niece would love to have the two guys from Twilight(I think their movie names are Edward and Jake); they'd think they were in heaven. Puppy love they are 10 and 11.
Okay I thought that I understood the process but obviously not. Here's my attempt at creating a cutfile of my daughter. It looks neat but not the same effect. Okay I will have to wait for the tutorial.
Calgal
Shirltop- your grand daughter is way too cute!
http://www.thymegraphics.co.uk - home of the Black Cat Cougar
http://www.blackcatforum.com
Bryan
Your images are incredible. Nice work!
Keep up the great work!
Debi
Can't wait to see your daughter all finished.
