What is threshold?
makeupgirl217makeupgirl217 Member Posts: 24
edited December 2009 in Help for Make The Cut
What is threshold? How do I know if I need to increase or decrease?
    Basically, when you load in an image; if it doesn't look right then set it to 10, click preview -- if it doesn't look right then, increase it by 10 to 20 ... work your way up to 250 if you need to -- but chances are it will look fine after the first few previews.
    It just sets the what pixels in the image will show through... the lower the number, the more pixels will show through. The higher the number, the less pixels will show through.
    After playing with it a bit you will see what i mean...
