Compatible Software for Labels
jtindeljtindel Member Posts: 1
Is there software available to "Make the Cut" for sticker labeling?
  • Liz_ALiz_A Member Posts: 10,357
    @jtindel - not that I am aware of. Make The Cut! is not a mainstream software by any stretch of the imagination. You should have success using the Avery label plugin with Microsoft Word...Avery has design templates available for download from their website here: https://www.avery.com/templates
    Make The Cut! can be used to manually (you do the work) create designs that can be cut from sticker or label papers of a variety of sizes, however, as I have indicated, you do the design work.
    Hope that helps, good luck!!
