Folders
I have my Saved file folders in alphabetical order In MTC, but when I logged in today, they were all scrambled up. How can I alphabetize again without moving each folder manually?  TIA
    I assume your using windows ?
    and when you display the open file dialogue your folder are not sorted as you want
    Try clicking the white space on the window and  > SORT < the choose the option eg: name
    @lynnscraps - how you see your items displayed in a folder is not dependent on the program you are using, it's totally dependent on the sort order set by the user in the computer's operating system, so if it changed, it was a user change, not a program change. :)
    To reset the sort order for all programs, press the Windows logo key (the one with the Windows logo on it on the left side of the bottom row on the keyboard) plus the letter e. This brings the File Explorer window. Click This PC on the left side. Click View, then on the Sort section set up how you want to view.
    The Sort by  and Group by options have similar choices to what Paul showed above.
