How do I get the cut.
When I hit send the auto blade goes all the way to the left and is not cutting on the material. How do I get it to move to the material I need to cut?
    Welcome to the Make the Cut 3rd party software forum.  MTC works with a variety of different cutters.  You have not given us much information to go on in order to help you out.  We need a little more detail.  Are you using MTC software with your cutter?  What cutter are you using? The more detail you provide, the better someone can assist you - even if it is to point you to another source depending upon the software and cutter being used.
