MTC download software
redhotrn65redhotrn65 Member Posts: 18
edited May 21 in General
Had to redownload the MTC software on my new computer. It has plug in installers to install for different machines but the brother scan n cut isnt on there. Do i need to install another kind for it to work?
    edited May 21
    Make the cut has not been updated for year so does Not support cutting directly to most new model cutting machine including  the scan a cut
    So there is no plugin for brother machines
    You can export designs from make the cut to svg file which I think you would be able to use with the scanncut machine or software ?
    I assume brother has prevented third party provider offering direct support
    As I understand Sure Cut a lot (another 3rd party provided cutter Software which is still actively updated )  also doesn't support cutting directly to brother cutters
    it allows export as svg and also brothers fcm file format
  • MeFlickMeFlick Member Posts: 9,209
    The Brother Scan N Cut was never a supported machine and has never had a plugin developed for it. as Crazy_Mr_Zing noted, you can export your design out of MTC to an SVG file and import that into any software program that allows for the importing of an SVG file.
