Cutting too small an in wrong place
kristykristy Member Posts: 48
New laptop, new Cameo 3. Everything looks good in the preview, pic, but the outcome is pic 2. Not only is it cutting in the wrong are and small, it's also cutting at the top of the mat. Help please.
Follow Me on Pinterest
  • MeFlickMeFlick Member Posts: 9,219
    First, unfortunately MTC has not been updated in a large number of years.  :( Which means that there have not been any cutters added as new cutters have been introduced into the market in all of those years either.  This would include the Cameo 3.  As a result, you may not be able to use the Cameo 3 with MTC. I cannot remember if anyone found a workaround for the Cameo 3 or not.
    I don't have a Cameo 3 so I don't know where its default cutting positions, etc. are. One thing to note, you have MTC set up to load the mat in in landscape mode (notice the mat position on screen with the arrow on the left)  not portrait and you have it setup with your items in the top left side of your mat so I would expect it to cut on the top, left. If you feed your mat in the same way, with the arrow into the machine first - it cut where I would expect it too in the top left.  It is just shifted too far left and upward in the actual cutting.
  • kristykristy Member Posts: 48
    I changed the orientation an it still wants to cut over on the left. I tried it on the old laptop an it cuts on the correct side but an inch+ too high and an inch+ in. Hope they get an update out soon.
    edited May 18
    kristy said:
    . . .  Hope they get an update out soon.
    It has been 6 years without any updates so I don't believe a plugin for any of the newer cutters or anything else will be coming out unfortunately.  :'(
    You can use MTC and use it to save the file as an SVG file and then take that SVG file to another cutter program that will let you import the file to cut. You can also look into SCAL software that is a 3rd party program that is keeping updated and adding support for new cutters. You can also try to use MTC, but figure out where it is off in the cutting and placement and adjust for that.
  • SassyLady_LisaSassyLady_Lisa Member Posts: 1,129
    @kristy If you have Silhouette Studio Designer Edition you can import svgs saved from MTC. My only problem with that is that it doesn't import textures correctly, so I finally learned SS. I have never used MTV to cut to my Cameo 3.
    Live Love Craft
  • 1cardcreator1cardcreator Member Posts: 846
    @kristy ; In MTC, right under orientation, you can try clicking on show margins, that may help you. I have a Zing and use MTC, but I had a problem with cutting orientation when I first started and it was because of the mat controls, and it had nothing to do with Portrait or Landscape, I had the wrong mat chosen and it had different margins than the 1 I was using.  ~Diane
